Pioneer SA-500 Restoration Help Bad CH2
  • #16
    forgot to mention that the old VR4 had very high resistance readings, in the K ohms.
    and it looks like there is some kind of white substance or glue. I will see if I can force it to turn and if a cleaning can bring it back to operattion.
    edit: I was able to scrape away the white stuff and rotate and clean the pot. It reads over 1M resistance so it is a goner.
    Click image for larger version  Name:	IMG_20230711_142539578.jpg Views:	0 Size:	377.3 KB ID:	984222 Click image for larger version  Name:	IMG_20230711_142425111.jpg Views:	0 Size:	737.4 KB ID:	984223
    • #17
      VR4 should be a 100R trimpot. Try to find a similar size/footprint. Wattage rating is not critical.
      If the idle current is too low there will be crossover distortion.
      • #18
        So far no luck sourcing a 100R trim pot with 2 legs. Anyone know some sources? Do I have to use a 3 leg pot?
        The old pot has a 10 mm spacing between the two legs.
        Thank you
        • #19
          I'd just clip one leg off a regular pot. Look for a trimmer with approximately 10mm spacing between the center and one outside leg. It should be easier to find.
          • #20
            Not many 100 ohm pots out there. I found a trimmer. see pic.
            The outside legs are 10 mm apart.
            I am thinking that I can jump one outside leg and center leg. Then insert the outer legs to the board. Make sense (will this work)?
            • #21
              That should work just fine as you described.
              • #22
                Finally got the new trim pot installed. Amp can be insanely loud for its size.
                Adjusted to @ 13 mV voltage across the emitter resistors of the outputs (R31,32,33,34). Need to lookup if this is a proper value. It was the lowest I could get them to be matching.
                • #23
                  I had to replace both trim pots to get both sides around 5 mV across the emitter resistors of the outputs (R31,32,33,34)
