Pioneer SA-500 Restoration Help Bad CH2
    forgot to mention that the old VR4 had very high resistance readings, in the K ohms.
    and it looks like there is some kind of white substance or glue. I will see if I can force it to turn and if a cleaning can bring it back to operattion.
    edit: I was able to scrape away the white stuff and rotate and clean the pot. It reads over 1M resistance so it is a goner.
    Click image for larger version  Name:	IMG_20230711_142539578.jpg Views:	0 Size:	377.3 KB ID:	984222 Click image for larger version  Name:	IMG_20230711_142425111.jpg Views:	0 Size:	737.4 KB ID:	984223
      VR4 should be a 100R trimpot. Try to find a similar size/footprint. Wattage rating is not critical.
      If the idle current is too low there will be crossover distortion.
        So far no luck sourcing a 100R trim pot with 2 legs. Anyone know some sources? Do I have to use a 3 leg pot?
        The old pot has a 10 mm spacing between the two legs.
        Thank you
          I'd just clip one leg off a regular pot. Look for a trimmer with approximately 10mm spacing between the center and one outside leg. It should be easier to find.
            Not many 100 ohm pots out there. I found a trimmer. see pic.
            The outside legs are 10 mm apart.
            I am thinking that I can jump one outside leg and center leg. Then insert the outer legs to the board. Make sense (will this work)?
              That should work just fine as you described.
                Finally got the new trim pot installed. Amp can be insanely loud for its size.
                Adjusted to @ 13 mV voltage across the emitter resistors of the outputs (R31,32,33,34). Need to lookup if this is a proper value. It was the lowest I could get them to be matching.
                  I had to replace both trim pots to get both sides around 5 mV across the emitter resistors of the outputs (R31,32,33,34)
