Phone plugs and jacks?!
  • Phone plugs and jacks?!
    I am currently working on an SWR California Blonde acoustic guitar amp. I have worked on several SWR amps and one other California Blonde amp. I have never seen the boards connected with RJ45 phone jacks and plugs! I don't know if this is a genius idea or the stupidest idea ever!
    Oh, oh, telephone line,
    give me some time,
    I'm living in twilight
      Well, when you are designing stuff, you look at how many connections are needed, and, cost. So i guess it was approved by the lead engineer.
        I guess it makes sense for ease of assembly.
          The RJ45 contacts are rated at 125VAC / 1.5A so, if the signals are within that spec in the SWR California Blonde, they should work OK. Per my experience the RJ45 is a very reliable connector system. However, they are not "Key-able" so that increases the probability of mis-connections when the amp is serviced. I wonder what would happen if someone thought they could connect one of them to an Ethernet port?
