Tung-Sol 6L6STR fragile bottle top
  • Tung-Sol 6L6STR fragile bottle top
    So today I finished a build and was ready to test it, when I took a brand new pair of 6L6STR TungSol's and tried installing them on the amp. Never tried these, so was pretty excited with the elegant tiny bottle.
    I was distracted and not really paying attention to such a trivial thing that's repeated 200 times a day at a shop: squeezing in a brand new pair of tubes into the octal sockets.
    Well, what do you know.
    As I pushed the tube in a loud pop surprised me, same noise as a light bulb exploding on the floor. I look and see my finger IN the tube....the thing blew up in my hand, cold, no significant pressure applied.
    I notice a perfectly cut circle has been opened at the top of the tube. I look at the other tube from the pair and it seems like that's where they sealed it, as if they fused the glass at the top. My finger is ok, because the circle is so perfectly cut, it's not even too sharp....but I could have really hurt myself there.
    So, warning everyone, be careful when working with 6L6STR's, the top of the bottle will pop into it with very little pressure. Make sure to insert these from the base, I don't know how safe the overall envelope is either, considering I did not apply very much force onto it. Needless to say, this had never happened to me before, and I've done much worse in the past.
    My camera had no memory chip at the workshop today, I had brought it home. I will post pictures as soon as I can.
    Valvulados
    As promissed, here are the photos of the 6L6STR. Note one on one photo the other undamaged tube, you can see the slightly lower edge exactly where it punched a hole through.
ID:	820592Click image for larger version
ID:	820593Click image for larger version
ID:	820594Click image for larger version
ID:	820595Click image for larger version
    Valvulados
      Autopsy of the Tung-Sol 6L6GC STR - Part I
ID:	820597Click image for larger version
ID:	820598Click image for larger version
ID:	820599Click image for larger version
ID:	820600Click image for larger version
ID:	820601Click image for larger version
ID:	820602Click image for larger version
ID:	820603Click image for larger version
ID:	820604Click image for larger version
      Valvulados
        Autopsy of the Tung-Sol 6L6GC STR - Part II
ID:	820607Click image for larger version
ID:	820606Click image for larger version
ID:	820608Click image for larger version
ID:	820609Click image for larger version
ID:	820610Click image for larger version
ID:	820611Click image for larger version
ID:	820612Click image for larger version
ID:	820613Click image for larger version
        Valvulados
          Yet ANOTHER good reason to turn off the power when installing tubes. You woulda gotten bit REAL good! :O
          John R. Frondelli
          "Mediocre is the new 'Good' "
            After I looked at my finger and it had not been sliced, the second thought was exactly "my goodness, if this thing was on....."
            Valvulados
