Batteries to increase Anode voltage in LoV designs?
  • #16
    Microphonic when used in your project or when used in a regular amp? I have seen 12au7/12at7 variants be microphonic when used in a amp. I haven't swapped out many at low voltage to come to that conclusion. If you were closer I would send some tubes to you.
    • #17
      They were microphonic in regular amps - at high voltage (300V, the preamp i made for my G-2000) as well as at relatively small voltage (120V, V1 position of Echolette M40).
      Do You think this will be better at ~20V? Well, easy to try.
      But regardless of that i need somewhat more complexity in the circuit because a bass guitar loses its power if its low registers are too much disorted - they should remain pretty clean. And i would like to be able to have some fine control over the amount of distortion.
      • #18
        For your possible intertest.
        https://www.ti.com/lit/an/snva731/sn...oogle.com%252F
        Cheers,
        Ian
