I have an MXR Phase 100 that I've been working on. It came to me completely broken, but I got the phase effect to work. The problem is it is distorted. I have done the diode check on all the transistors and checked voltage on all the op amps, and nothing comes out abnormal. Could anybody offer some advice as to what I might look for next?
MXR Phase 100
Under what circumstances is it distorted, and could you perhaps describe the nature of the distortion a bit more?
Note that since the P100 uses optoisolators instead of FETs like the P90, there should be no distortion resulting from things like misbiased FETs. As well, since it does not use JFET switching like a great many other commercial phasers, there should be no distortion from that source either.
Ok I got a schem and layout for this pedal on General Guitar Gadgets and they do not match. The schem shows that R53 is grounded but in fact the layout shows it is connected to the 9V supplyAnyone know which is correct? I've filled out their contact form but no reply yet.
