I took apart my crybaby tonight because I wanted to switch a few things around after modding it a while back. I did the true bypass, gain resistor, vocal resistor, low range cap, and mid boost resistor mods found at this page, and also removed the buffer circuit last time. This time I wanted to replace the gain resistor with the original value, and switch to a different model of cap for the low range. When I went to test it out tonight, it was dead! Signal passed through when the effect was turned off, but not when on. I tried a good battery, made sure that it was powered, but with no luck. I'm a beginner at electronics - any advice? What should I check first? Help!!
