Hello,
I have a line 6 dl4 which several years ago stopped working. I had the same problem as a previous poster in this thread where it would only function if I pressed the power adapter into the jack.
I brought it to a local music shop to have it serviced. I went back a week or so later and the tech claimed he had fixed it. He also told me that in order to fix it he had to disconnect the wires to get power from the batteries and connect them to a new power adapter jack. He claimed that the pedal did not require 9V but only 6V and that is why he did this.
He had already done the work, and it was now functioning so I dealt with it. I have used it with a 6V power supply ever since.
My question is I am considering getting one of the 1 spot power supplies and the Line 6 adapter. Will this fry my pedal because it is now connected using the battery terminals which only require 6V?
