Awe man..... As instructed I sent this pedal back to Demeter because of the volume boost issue, and also the switch made a loud click even when you lightly touch it.
A little under a month later I got it back, apparently the only mod done was snipping a resistor out (See pic. , Area above green cap). Now It sounds a tad thin, and there's a slight volume drop at most settings.
The switch still had the problem.
I installed a 3pdt and that fixed the switch. Then I started experimenting with some new resistor values in the old location, In the process the damn thing stopped pulsing. At first it would still pulse if I pressed down on the closest chip to the mod... But then it quit all together.
Now the depth knob decreases the pedals volume when turned up, ........and it doesn't pulse.
I tried to touch up the solder joints on the chip socket, but no luck.
Any suggestions?
Thanks in advance !!!!!!!
Any suggestions?
