Here's the problem. When bypassed, the signal is fine. When the effect is activated, however, the LED lights up but the signal is very low in volume. With the amp cranked, you can just barely hear the phased signal. The problem is there on battery power, or line voltage.
FWIW, there was no shock to the unit, or other trauma. One day it worked, then suddenly it didn't.
Any ideas as to what element is not working would be very much appreciated. Thanks in advance.
