Summer Fund Drive:C'mon guys lets show some support! If this site has helped you an you haven't recently donated Include your username so I know whos donatingPlease consider making a donation. :)
View will be from bottom, with jacks facing away, calling FROM the board TO the switches. If the wires are still connected to the battery/switches, I'll give the wire colors, in case they are the same:
Battery +: to the Red +, left of center jack, middle hole, vertically.
Battery -: to the Black -, left of center jack, top hole, vertically.
Just under those is another hole. That (blood-red) goes to the right-middle connector of the left switch.
Moving left, bottom-most hole, between the battery and the left switch cutout, (green) to bottom-right connector of left switch.
Moving left, just slightly above, (yellow) to the top-right connector of left switch.
Left of that, (orange) to the top-left connector of the left switch.
Left of that, (blood-red) to the middle-left connector of the left switch.
Finally, on that side, left-most, (brown) to the bottom-left connector of the left switch.
That should cover the battery, and the 6 connectors of the left switch ("A or B" switch).
On the right side:
The right-most bottom hole goes to a ground washer sandwiched between the switch and case (black).
Down and to the left, (white) that hole goes to the top-right switch connector.
Up and to the left, (gray) that hole goes to the middle-right connector of the right switch.
Down slightly and left, (brown) that hole goes to the middle-left connector of the right switch.
Finally, almost directly above that, (blue) goes to the top-left connector of the right switch.
So, on that side, you have a ground, and 4 connections for the ("A and B" switch).
