So I have an old MXR Flanger with the 3001-102 PCB, so it's from '77 or around then; grey box. I plug it in and this is what happens:
All of the following symptoms show up whether the pedal is bypassed or not. When the pedal is engaged, the volume drops a little, but behaves the same.
- I can hear the guitar, but it is pretty quiet.
- Lots of noise and fuzz
- A beat. It goes around 3 to 4 beats per second at it's fastest and when it beats the guitar and noise go away. The beat it louder than either of the other two.
- If the Manual knob is turned all the way down, the pedal goes silent.
- The Regen knob acts like a tone control, like an LPF. With it all the way down everything is very muted and dark.
- If the Width knob is turned all the way down, the pedal goes silent.
- The Speed knob does what it's expected to do; it controls the speed, or rate, of the beats. It maxes out at about 3 or 4 beats per second and all the way down it is something like 1 beat per minute. Sounds like a freakin' metronome.
What I know:
- The power supply is fine. All power is at the correct voltages.
- The switch is fine.
- When I assemble/disassemble the pedal, the symptoms sometimes change.
- I measured the voltage coming out from the effect, and it was about 9.8v DC. I can't remember if it was negative or not.
So my thoughts: (for what it's worth)
- The clock/timing chip is working. Woo.
- Something is wrong with the grounding (the switch tested fine, so the fact that the problem exists even with the pedal disengaged means something with the grounding is wrong)
- The bucket brigade chip may be toast/having issues.
Unfortunately, the delay chip is a Reticon SAD 1024, which I understand is very, very difficult to come by these days. Not only that, there is no pin for pin replacement that will cut it.
Note: this schematic is for the 4001-102 series. The polarity of all the major caps is opposite. Also, the voltage regulator looks like a regular little transistor; not one of those with a heat sink hole as pictured in the layout. There may be other differences; but almost everything is the same.
I have an idea, but I wanted to run it by somebody with a little more know-how and experience before I tried it, for risk of damaging something. The delay chip is socketed; could I confirm a delay chip problem by removing the delay chip testing whether it continues to make it's annoying metronome?
So... anybody out there?
P.S. Thanks in advance, everyone I've met on this forum is the best. I greatly appreciate your help. To say the least, learning this way beats school :P
What I know:
