Ive made a pedal using this circuit. Accept im using a 12ax7 and my B+ is 115 volts not 24v. It makes alot of noise and i realize now the resistors need to be of different values. i dont know how to calculate this stuff. Anyone know what i should change them to in order to make this pedal useful. thanks
Cathode Follower Buffer Pedal.
Originally posted by Wilder Amplification View Post
ive got a couple 12ax7's laying around that all. this project was made from left overs so i want to see how it works out before i buy anything
If you were to replace those values with around a 7.5K/1M, you can double the input headroom but you won't have much current drive, which would defeat the purpose of the buffer in the first place.
12AX7s, while they can work as a cathode follower buffer, are best suited as voltage amplifiers. 12AU7s are a much better valve to use as a current amplifier than a 12AX7 would be, which is basically what a cathode follower buffer is. It amplifies current so that you can drive lower loads without the load sucking the output voltage down.
With a 12AU7 at the same voltage and a 800 ohm/22K combo, you'd have about 4Vpk-pk of input headroom (which is more than enough for most passive guitar pickups) and just over double the current drive than you'd have with a 12AX7.Jon Wilder
Originally posted by m-fineI don't know about you, but I find it a LOT easier to change a capacitor than to actually learn how to play wellOriginally posted by JoeMI doubt if any of my favorite players even own a soldering iron.
Maybe the tube is oscillating due to the lack of a grid stopper resistor. Try a 10k in series with the grid, right at the socket pin.
It looks great, but I'd be terrified of treading on the tube by accident."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
This is my power supply. i used 2.2uf for C1 and C2 and 10uf for C3 and C4
Its running in paralell with the AC heater. I used the negative as a ground.
then ive got a simple rectifier to power the led. accept i didnt ground it like this drawing says.
maybe my problem is with gound loops. it make a loud buzzing sound. im affraid to hook up a guitar just yet. If i pull the tube the noise should go away if the problem is the tube circuit but not if its the power supply right.
Originally posted by NFXP View PostThis is my power supply. i used 2.2uf for C1 and C2 and 10uf for C3 and C4
1. Drop the 470K resistor down to 100K.
2. Ensure the input jack and output jack are isolated off the chassis..
3. Tie all ground connections to a common point inside the device.
4. As a side note, and I did this once, wired up the input jack backwards with the ground lug feeding the input, and the signal lug wired to ground... Not saying you did, but something to double-check..
-gLast edited by mooreamps; 01-25-2011, 08:28 PM.
Originally posted by mooreamps View PostIt probably could be caused by ground loops coupled with the very high input impedance with the circuit.. I would :
Originally posted by NFXP View Postive got a couple 12ax7's laying around that all. this project was made from left overs so i want to see how it works out before i buy anything
no one drools over pictures of "*Any* op amp buffer , or even a single Fet, Mosfet or even humbler bipolar" buffers. If i really needed a buffer i would have bought one already.
What JM wanted to say, (rightfully IMHO), is that, of all the tube-based circuits, the buffer is possibly the one in which the peculiarities that make us all love tubes so much are not exploited at all. The buffer acts as an impedance adapter, its gain is (slightly less than) one, and its behavior is extremely linear, so it really makes no difference whether a buffer is based on a tube or not. The behavior is so similar that even some purists would accept the presence of a MOSFET buffer in an otherwise "all tube" amp, so, if we're talking about a tube buffer pedal, the "cons" clearly outweigh the "pros".
JM2CW
Best regards
BobHoc unum scio: me nihil scire.
