I haven't seen the oscillation problem you mention yet. Don't forget that there's a bias oscillator that turns on, so you may be seeing that, which is normal, when you start recording, if you're poking around with a scope probe. If it's audible, then it's not the bias oscillator.
There are 2 playback heads and 3 record heads. The 3 volume knobs control the levels to the record heads. The output levels should be the same at the same settings of the control, and this can be adjusted using the level pots on the side (not the bias level pots).
These machines are complicated and difficult to work on - I'm looking at it as a challenging and fun project, and when I get frustrated I put it aside...
Bob
Bob
