The echo sounds may be distorted because your direct sound which is used for recording is distorted.
Are you sure valves 1 & 2 are OK? Does the indicator valve (6) show distortion or are the green bars apart when the distortion is heard?
Are your HT filter capacitors OK?
Anodes of valve 1 should have 150V on them, valve 2 should have 100V (pin 1) and 200V (pin 2)
R17 may be adjusted to high in value allowing the signal to overload valve 2.
Once you have the direct signal sounding "good/great" then we'll move to the playback section.
Cheers, Mickey
Cheers, Mickey
