Digitech RP 1000 burned
  • Digitech RP 1000 burned
    Hi!
    This is my first post so i hope to find any help on this matter.
    My RP1000 received a mayor peak of voltage on one of mi gigs and stop working, meaning, there's no sound out of it, the lights are on, the switches work, but cero sound. When i finally opened i've found this completely burned.
    https://drive.google.com/open?id=0B3...i14VGx2OXpLRlE
    So i've oredered the piece, it's a MP1542, hoping that when i change it my RP it's going to be back. I have cero experience on changing SMD components and i doesn't know the implication of such damage on other components and i will apreciate any help and pointers on this matter.
    If you have no experience removing SMD components, you can try ChipQuik:
    You have nothing to loose. In the worst case it will burn again.
    Mark
      Make sure none of the diodes are shorted: D15,D16,D22 and D23.
      http://music-electronics-forum.com/a...1&d=1498237446
        Hey thanks, i'll check those ones
          Diods 15, 16 read 262
          Diods 22, 23 read 222
