Hi,
I want to to rewire an AB-Looper so it only switches on one channel at a time and also switches the amp channel at the same time. Right now, when A or B is active, and I press the switch for the other channel, both turn on. First, that's really annoying because you have to press two switches to switch from clean to distortion, and secondly you also have to press a second switch to change the channel on the amp. I'd like to have a pedal that can switch between two different FX-Channels and switches the channel on the amp at the same time. Can anyone help how to rewire it, or maybe even give me a new diagram
thank you in advance
