PCB mounted DL4 switches - source?
  • PCB mounted DL4 switches - source?
    I just scored a used DL4 in trade & one of the board mounted switches is only working ~25% of the time. I know about the springy actuators & this is not the problem. I've run the pedal with the guts out & even using a pencil eraser directly on the switch it doesn't work reliably. Looks like it'd be plenty simple to de-solder and replace, I just can't find a source. Anyone been down this road already?
    Also, while I'm at it, the pots are all kind-of wobbly, anyone found these?
    Yee-haw! I hadn't had any luck searching for the answer before, but I finally found the right string & it yielded a post about these switches on the Line 6 forum.
    The part # is: TL1100DF160Q and the OEM was E-Switch. They are readily available for under a dollar from DigiKey, Mouser, etc. I'm going to get 10x on the way ASAP.
    I'd still like to know the pn# for the pots as it'd be nice to replace them too, but I'll certainly settle for the switch for now. . .
      Hey thanks for this info!
      I have a DL4, and while mine is in great working shape, I've heard from a very reliable source that the switches aren't very reliable. I'm gonna bookmark this info and tuck it away in case it's ever needed.
      Robin F.
      Karaoke - the Japanese art of death by music.
        I've already fixed 2x 'broken' DL4s with this info. Good stuff.
