Those connections are tight. I dont hear any noise when pounding the unit. I had a couple of Electroharmonix effects in the past that also amplified the mechanical click in the past. THere must be a solution to this.
Is it ACTUALLY amplifying the mechanical action? Or is it really that WHEN you click the button a pop or crack sound occurs in the signal? Those are VERY different things.
