Zener diode replacement for W03C
  • Zener diode replacement for W03C
    Hi all,
    I've got a TS-9 Tube screamer. The zener diode, which I have to replace, in the power supply is part number W03C but it's listed as obsolete at most part houses. Is there a replacement or substitute for this diode. I think it's there so you cannot hook up an adaptor (wall wart) backwards to the circuit and damage the pedal. it's a 9 volt circuit, battery or wall adapter. Any recommendations are appreciated.
    Thanks,
    Bob M.
    I think it may be just a regular rectifier diode (reverse biased)? Do you have the right schematic for your version that you could post?
      The only zener is in the switching circuit (RD4.7EB). W03C is a standard 1A rectifier diode (used for wrong polarity protection at the power supply input).
      https://www.datasheets360.com/pdf/4885999905650181930
      You can use a 1N400x (the x standing for 1...7).
        Here is the TS-9 schematic.
        Yeah, the W03C is just a reverse protection diode.
          BTW, this "protection" diode is a very bad solution. While it mostly protects the unit's electronics against wrong supply polarity, it shorts the power supply and may kill it.
          A much better solution is to wire a Schottky diode in series with the positive supply input.
