I've got an old 'Powerbank' from the 1990s which supplies 5 lots of 9v for effects pedals. I haven't used it for about 20 years and when I plugged it in it's very noisy, so I assume the electrolytic filter cap (2200uf 25v) has dried up. I've ordered a replacement but could only order a minimum of 2, which prompted the question: is there anything to gain by wiring them both in parallel to double the available capacitance, or is one x 2200uf more than adequate for the job? Cheers!
Recapping humming 9v power supply
Originally posted by greengriff View Postis there anything to gain by wiring them both in parallel to double the available capacitance, or is one x 2200uf more than adequate for the job?
- Likes 1
Hi
You mentioned the replacement (2200uf 25v) and thought that it would do would better filtration if in addition to the existing one to install in parallel another one (2200uf 25v) .
If Powerbank have a voltage regulator, subsequent install parallel cap will not affect the improvement of filtration because the voltage regulator at the same time performs filtration.
If you are already deciding to replace the cap, let the choice be low-esr caps and for 105 ° CIt's All Over Now
- Likes 1
Originally posted by vintagekiki View Post...If you are already deciding to replace the cap, let the choice be low-esr caps and for 105 ° C
- Likes 2
