DIP14 741 opamp
  • DIP14 741 opamp
    I got these recently and I was wondering if those are really 741 opamps. Also which manufacturer is that?
    Click image for larger version  Name:	741IC-Pin-Configuration_01.jpg Views:	0 Size:	114.6 KB ID:	912439
    https://www.digchip.com/datasheets/parts/datasheet/477/UA741IP-pdf.php 1)
    It's All Over Now
      I don't recall that MFGR symbol, but, the 8-pin DIP CAN plug into the 14-pin DIP pattern directly, if you look closely. Skip Pins 7, 8, 1, 2, 13 & 14.
