A „Vox-Wah“ project, some circuit analysis and measuring results.
  • #61
    Originally posted by vintagekiki View Post
    Vox Wah OS/158
    Click image for larger version  Name:	wah_os158.jpg Views:	4 Size:	515.2 KB ID:	927090
    https://www.voxsupreme.org.uk/vox_wah_wah_pedals_1967.html
    Vox Wah OS / 158 uses inductor 0.25H (1/4 H)
    Interesting from a historical POV. Seems this version didn't stand the test of time.
    The 0.25H inductor with the 10nF cap will shift the frequency range from 440Hz/2.2kHz to 640Hz/3.2kHz.
    Also interesting the log pot and the pnp transistors.
    • #62
      Interesting from a historical POV. Seems this version has not stood the test of time.
      Frequency range 640Hz / 3.2kHz goes more in HiMid.
      Maybe should try how wah “by ear” sounds with a 1H inductor.
      It's All Over Now
      • #63
        It is easier to vary the feedback capacitor value, as in the Dunlop Cry Baby 535Q.
        For me the range from 440Hz to 2.2kHz is optimal to get the Hendrix sound.
        • #64
          2.2kHz will be obtained both with 1H and 4.7nF, the only question is how the LC (XL, XC) ratio will affect the sound.
          It's All Over Now
          • #65
            A higher L/C ratio means higher impedance and thus especially a higher bass peak. But resonant Q will be lower.
            (In simulation the effect on peak height was small but Q dropped from 12 to 8.)
            The height of the bass peak strongly depends on the DCR of the inductor.
            I have experimented with 0.65H/8.2nF but I think I like the 0.5H/10nF combo best.
            • #66
              Schaller Wau-Wau Yoy-Yoy a dual-inductor wah
              https://www.tonehome.de/schaller-electronic/yoi-yoi-bow-wow/
              https://www.fingers-welt.de/phpBB/viewtopic.php?f=14&t=9568 1)
              Click image for larger version  Name:	file.php?id=26352.gif Views:	0 Size:	12.1 KB ID:	927151 Click image for larger version  Name:	367839-BowWowYoyYoy-gif.gif Views:	0 Size:	8.8 KB ID:	927152 Click image for larger version  Name:	schaller_wow-wow_sch.pdf_1.png Views:	0 Size:	3.3 KB ID:	927153
              It's All Over Now
              • #67
                Yes, I remember those. Had Schaller and Höfner wahs in the 70s (couldn't find/afford the real thing).
                Never had a use for the second resonance Yoy-Yoy effect.
                Looking at the schematics, I think the added gain stage followed by a voltage divider at the output makes no sense.
                It might produce a little unpleasant transistor distortion, though.
                • #68
                  I played around with the "Q" control of a Dunlop 535Q wah and must say that I found it quite useful to lower the bass peak height and Q, when the wah is connected to an overdrive or distortion pedal.
                  So the addition of a variable resistance in series with a low DCR inductor like a Dunlop red Fasel seems to be a good idea (much more so than a variable parallel resistance).
                  Here is an excerpt from the 535Q manual (note recommendations for variable Q settings):
                  • #70
                    Don't understand what you mean.
                    I designed some inductors early in my job and know the basics (and a little more).
                    The Q of the inductor is vastly different from the Q of the resonant circuit:
                    https://www.gitec-forum-eng.de/wp-co...E_Q-Factor.pdf
                    My post #68 above is about sound.
                    • #71
                      Post # 17 is about the Q factor of inductor, which is an integral part of most wah.
                      It's All Over Now
                      • #72
                        As said and explained earlier, the wah sound depends on the Q (width) and the impedance (height) of the resonance as well as the lowest and highest peak frequencies
                        The Q factor of the inductor is one influence among several others and it strongly depends on frequency.
                        • #73
                          https://components101.com/articles/how-does-quality-factor-impact-the-performance-of-an-inductor
                          For the same frequency and the same inductance, the Q factor depends from the resistance. On the influence of resistance to Q factor post # 17
                          It's All Over Now
                          • #74
                            I know, but it's not about the Q factor of the inductor but about the the Q of the resonance, which is a different story.
                            The Q-factor of the inductor, more exactly its ESR has some influence on the resonance Q and impedance, though.
                            • #75
                              Sorry, I'm free to ask.
                              It is known and I know what is the Q factor at inductor.
                              I don't understand the term "resonance Q" or "Q of the resonance"
                              ESR at inductor, coming with high frequencies (HF).
                              It's All Over Now
