Jen Crybaby - what's with the Vox soft bag?
  • Jen Crybaby - what's with the Vox soft bag?
    I've had this Wah for decades but it always puzzled me why the bag is printed up with the Vox logo. The guy I bought it off had it from new and insisted that he bought it like this. So, the question is - is this really original to the wah, or did the music shop just sell the pedal with a different bag they had lying around? Interestingly the pedal has the less-common green fasel inductor. This has been my 'keeper' pedal for all my band years and my reference pedal for what a good wah sounds like. I went through quite a few pedals over the 45 years I've been playing but once I got this I stopped buying.
    Click image for larger version  Name:	PICT4423.JPG Views:	0 Size:	1.13 MB ID:	923802 Click image for larger version  Name:	PICT4436.JPG Views:	0 Size:	1.04 MB ID:	923803
    The Vox bag looks original. Should have at least one of those somewhwere.
    AFAIK, most early European Vox Wahs were made by the Jen factory/Italy and have a number of Italian components, esp. pot and caps.
    Will post a picture of my early 70s Vox Wah later, which looks almost identical.
    Your Wah is actually the first one I see that seems to have an original Fasel inductor. Could you verify?
    I would also like to know if the inductor has a toroidal core.
    Does it have the original ICAR pot?
      As promised, picture of my early 70s Vox Wah. Original, except replaced pot, switch, battery clip and some wires.
        Found this in my basement and thought it was the old original one. But then I discovered the little tag inside saying MADE IN CHINA. So it must have come with a Click image for larger version
ID:	923887 later Vox V847 wah.
          I just took a look at the pot and did a rough paper plot and it is an 'S' taper. I've never replaced it and the solder joints are original. Markings are B4 811 6678 100K 583894. Whilst it's a 100k pot, it actually measures 194K. The Fasel green inductor is original but I can't confirm whether it has a toroidal core as the casing is glued together. My case doesn't say made in China but it looks to be the same. I can't think when I bought the pedal/case, but it's certainly before stuff started to come in from China.
            Thanks for your answers.
            I have my own idea about the origin of the S-taper often found in wah pots and the increased resistance seems to confirm it. I will explain in my Vox wah thread at a later point.
            Does it say Fasel on the inductor case?
              I x-rayed a few wah inductors. The Fasels are contemporary replacements.
              img019.pdf
