The title says it all - U7 blew up in my EHX Nano Metal Muff and I'm trying to ID this part. If anyone has one of these pedals they can crack open and let me know what part U7 is I would be very grateful. Thanks.
Help with ID of blown SMD chip in EHX Nano Metal Muff (U7)
Some of the lettering is still visible. If you can zoom in closer with a picture, someone might be able to identify from what is left of the lettering.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Agree. A picture of the IC close up and in focus would help. The metal muff schematics I've looked at have only 4558 op amp IC's, so that's my best guess without more info."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Check which labels (type) other ICs have. High probability that EH uses the same IC
https://www.freestompboxes.org/viewtopic.php?f=1&t=4961
https://easyeda.com/earthicko/Metal-MuffIt's All Over Now
Thanks guys, I've photographed and identified the other chips as best I can. U1, U2, and U5 are RC4558. U6 is LM393. Lettering on U7 doesn't appear to match either of those ICs. U7 also lacks the beveled edge and stripe marking, so I'm still at a loss. It's probably not a Ti chip like the rest.
Originally posted by vintagekiki View PostCheck which labels (type) other ICs have. High probability that EH uses the same IC
Originally posted by o2bthecream... the nano Metal Muff has a noise gate built in ...Last edited by vintagekiki; 07-30-2021, 12:17 PM.It's All Over Now
I will start tracing out from the controls to see what parts of the circuit they connect to to narrow down the function of the un-identified IC.
To begin with, power it up (guess it blew open and not shorted) , IF a dual Op Amp then pin 4 should be negative or ground, pin 8 should be +V, so near +9V
IF it leads to Power In jack, it might be a switching supply thingie, think one of those Maxim MAX*** or ICL**** charge pumps which generate -9V (-15V) or double +9V to +18V,etc. .
Here you might find a Korean version.
Just to look at it with more possibilities in mind.Last edited by J M Fahey; 07-30-2021, 04:17 AM.Juan Manuel Fahey
EHX Nano Metal Muff is a relatively new product of New Sensor Corp (2019). Schematics for the EHX Nano series I have not noticed. Judging by the environment, the defective IC is most likely some from the OTA series (CA3080, LM13600 ...)
May be helpful schematic for Deluxe Big Muff Pi, because it has Noise Gate.It's All Over Now
- Likes 1
https://www.coursehero.com/file/46901949/Electro-Harmonix-Metal-Muff-Schematicpdf/
https://www.freestompboxes.org/viewtopic.php?t=2184
EHX - Deluxe Big Muff Pi EH3053
The Deluxe Big Muff Pi has an OTA IC 3080 as a compressor.See #13
Somewhere passed (new) EH Deluxe Big Muff Pi , no traces left in the bookmarks
https://en.audiofanzine.com/fuzz-pedal/electro-harmonix/deluxe-big-muff-pi/editorial/reviews/pi-in-your-face.htmlIt's All Over Now
