Help repairing MXR Micro Chorus M148 SMD version (post 2008)
    R42, R43 Good ?
      apparently yes, as the pedal works again now
        Not sure if this warrants a new thread, but, would anyone be able to explain what the function of the TR1 and TR2 pots is? All I can figure out is that TR2 makes the effect come on and off depending on where it is in its sweep. I can’t figure out what TR1 does by playing with it.
          The trimmer labelled TR1 appears to be used for maximizing clock rejection by adjusting the balance between the two outputs of the delay chip (pins 7 and 8). The trimmer labelled TR2 would then by used to set the bias voltage required for the input signal to the delay chip to pass.
          What is the little 3-pin MOlex connector for? Does that connect to a battery snap?
            Thank you. Yes the 3 pin connector is for the 9V battery lead snap connector.
