I hadn't used this pedal in awhile and I found my stock EHX power supply was putting out 24v instead of the 18v.
I'm using my Ciocks power supply putting out 18v DC and the Bypass works as does the LED. When the effect is engaged I'm getting no signal through.
EHX used to fix this for a reasonable fee but are no longer doing that so I'm hoping I can bring this awesome pedal back to life. Here are some gut shots. I did some voltage testing around U6 and got some voltage at the IC but hoping someone can offer some other troubleshooting suggestions for what to check voltage wise. I'm wondering if the failed PS blew something which is resulting in the issue.
