1980s EHX Stereo Memory Man - Remove internal power transformer
    Success everyone!
    I had ordered the recommended power converter and a second one with wider input voltage range, which I ended up using. I installed it at the points recommended by dmeek, and used the fairly rudimentary power filtering circuit recommended in the data sheet for the part (but using 220uf and 33uf capacitors).
    Happy to report that this solution works perfectly, with very little noise despite this being an analog delay circuit!
ID:	980969 Click image for larger version
ID:	980971 Click image for larger version
Name:	Screenshot 2023-04-19 at 14.03.06.png
      Here's an update.
