Anybody have experience with dead WH-1s? I have one that doesn't function or light the LED. The photocoupler LED inside the pedal does light up, and I believe I'm getting the proper voltages from the 2 voltage regulators (U24 gets insanely hot but it is mounted to the shell). I've tried re-seating the socketed chips and looked around the board but nothing is jumping out to me.
Digitech WH-1 problem
What is the number on the -8V regulator? What are the voltages on the other pins? Could be -8V in and should be -5V out?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
See if the first 3 pages of these schematics is of any help: https://music-electronics-forum.com/...7&d=1530152707Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostSee if the first 3 pages of these schematics is of any help: https://music-electronics-forum.com/...p;d=1530152707
I would look for a crystal and see if you can determine whether the clock is running. Around that era it was fairly common to find bad crystals as they didn't seem to be able to take the kind of abuse (dropping, etc.) that modern ones can.
A datasheet for the CPU should also be helpful as far as where the clock signals should be.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostI would look for a crystal and see if you can determine whether the clock is running. Around that era it was fairly common to find bad crystals as they didn't seem to be able to take the kind of abuse (dropping, etc.) that modern ones can.
