I can't figure out how to upload a photo. I select the image icon, browse to locate the file on my desktop but then can't upload it. If I click OK it says image source URL is missing. The option is set to retrieve remote file and reference locally, but the file won't upload. Tried 'sent it to the server' and the button is inactive. Any advice welcome.
How do I upload a photo
Originally posted by Mick Bailey View PostI can't figure out how to upload a photo. I select the image icon, browse to locate the file on my desktop but then can't upload it. If I click OK it says image source URL is missing. The option is set to retrieve remote file and reference locally, but the file won't upload. Tried 'sent it to the server' and the button is inactive. Any advice welcome.
I first had the option of selecting size, then, finding large was way too large, I removed it and selected medium, which seemed reasonable. Trying to close gave an upload error message. Tried again, now I'm getting the small one, with a boxed '1' in blue. and no longer given options as to size. This is an on-going mystery to me in piecing together posts, no longer having the ease of the previous software, in that regard.
1 PhotoLast edited by nevetslab; 07-23-2020, 07:38 PM.Logic is an organized way of going wrong with confidence
The 'send it to the server' button worked for me above, then I had to ok the next screen ('image properties') where a filename had been entered into the URL box.
Originally posted by g1 View PostThe 'send it to the server' button worked for me above, then I had to ok the next screen ('image properties') where a filename had been entered into the URL box.
Now trying to find how to add text below the image, having stumbled thru the Upload tab to get to Browse, Send to Server, and fight the image size, since the size function is grey'd out.
I can't seem to get text below images as we could do easily before. I suppose there's a way to do it,
Last edited by nevetslab; 07-23-2020, 10:11 PM.Logic is an organized way of going wrong with confidence
When you click on the image icon in the toolbar, the pop-up box opens to the 'image info' tab. Click the 'upload' tab and you will get the 'browse' and 'send to server' buttons."Everything is better with a tube. I have a customer with an all-tube pacemaker. His heartbeat is steady, reassuring and dependable, not like a modern heartbeat. And if it goes wrong he can fix it himself. You can't do that with SMD." - Mick Bailey
nevetslab , you have to 'toggle advanced editor' to get the toolbar where you will find the 'image' icon."Everything is better with a tube. I have a customer with an all-tube pacemaker. His heartbeat is steady, reassuring and dependable, not like a modern heartbeat. And if it goes wrong he can fix it himself. You can't do that with SMD." - Mick Bailey
Nevets,
You may want to look at the settings in your camera/Iphone and just choose a lower resolution so your file sizes are smaller- at least for web posts. You can always change it back if you want a hi-res photo for something."Yeah, well, you know, that's just, like, your opinion, man."
image widget
Well,
After dozens of attempts I got this to work. Once. I haven't been able to repeat uploading a picture again. The time it was successful resulted in the system auto completing the image URL without me doing anything different, but now the buttons are dead again and I can't exit or cancel the dialog box without closing the browser - just stuck in a loop.
I just posted a new thread on a Mesa Mark V with a pedal problem. I was able to load the photos, AFTER writing the text, and, while it was awkward, it did load similarly to the old software...just more steps involved. But, after I was finished loading the photos, and the preview looked normal, as I had intended, Saving it yielded an additional array of photos in a separate box below the last of the text. Wasn't there when I previewed it. I did this from work using the XP machine, Firefox 59.2Logic is an organized way of going wrong with confidence
I got it to work again - doesn't appear to be affected by browser, though. I tried Opera as well as Firefox with the same results. When it does work I browse to the file, send it to the server and get a 'Working' message that auto-fills the URL. When it fails, I don't get the working message but it shows javascript:void (0). The problem seems to be that the server upload is intermittent.
- 2 likes
