Have a Tele with 3 EMG single coil active PU's. Too bright and fizzy. It has that weird .1uF cap between the volume and tone pots. EMG suggests to add more in parallel to change high-end roll-off.
I was experimenting, and connected a .022uF cap in regular fashion (from lug to tone pot case...while the other was still installed), and it seemed to tame the tizz pretty well.
Will wiring a cap like a normal passive pickup hurt the EMGs, or cause any other unwanted problems? May experiment with a few values, if it doesn't hurt... on both caps.
Thanks,
Brad1
Thanks,
Brad1
