I got my guitar wired up with Dimarzio D Sonic and PAF Pro. I have the PAF Pro installed with the wires on the side towards the bridge. The D Sonic is installed with the blades facing the neck (which means the wires are coming out on the side towards the neck).
I wired it as shown in the diagram here:
Everything sounds great, but the parallel configurations are quite noisy. About as noisy as a coil cut. Also, the 5th setting (inner coils) is quite noisy. I know technically they are not inner coils because of how the pickups are placed (should I flip the neck pickup?) but since the setting has one pickup’s north coil parallel with the other pickup’s south coil, shouldn’t it still be fairly silent?
Anyway, just curious if anyone sees anything in the diagram that would explain noise… The noise is a combination of hum and static. I used a continuity tester and confirmed that everything is switching properly.
Thanks,
brian
Thanks,
brian
