The one I have looks very much the same too. Now I just need to keep my wife from borrowing them! (She cuts wire for her gardening projects)
What's your favourite string cutting tool?
tonequester here.
It gets old ruining tools. Ive never found regular cutters that stand up to the hardness of steel strings. You mention getting close to the tuning peg, so I take it you're talking about cutting the excess string off after installation of a new set. Believe it or not, gripping the string by hand, or if remnent is not long enough, by pliers, one can use a Dremel tool with a small common aluminum oxide grinding bit, it works well, and the special cutting disks work even better. One does need to take some care, but it works a lot smoother than you might think. Just a light touch is all that's needed. If one uses a cutting disk, use the fiber impregnated ones, not the shatter prone/easily broken kind.
Every set of cutters I've ever tried to cut strings with,have been quickly damaged, and became useless over time. Just a suggestion. Best Wishes Steve. tonequester.
Wire cutters are designed and sold for cutting copper and aluminum, to be price competitive they use steel that is correct for that job. You can buy "Cable Shears" that will be rated for steel. I have some that were made for bike brake cables that work great on the bench but I just use the $3 harbor freight diag cutters in my guitar case.
Originally posted by Steve Conner View PostTitle says it all really. Whatever guitar strings are made of, it seems hard enough to destroy regular wire cutters and cheap cutting pliers. I'm currently using a set of Park Tool cutters intended for bike brake cables, but the jaws are so big that it's hard to get a neat cut near the tuning peg. There must be some better tool that you pro guitar techs all know about.
Hard-Wire Cutter | National Jeweler's Supplieswww.sonnywalton.com
I used to use a pair of Klein's linesman pliers, but I grew tired of stabbing my fingertips on the little sting that was left. Now I prefer to just wind all the excess wire / string into small loops. I think it looks cleaner / nicer and also prevents finger bruising. I can post a picture when I get home of my guitars.
I've just used a quality pair of wire cutters I purchased a long time ago at some hardware store. They cut through all strings including bass strings no problem with a neat cut. I've found the cutting edges on pliers and small wire cutters don't work well.
Greg
In case there is interest in the method I mentioned in post #2...
Self quoting from post #2 of this thread "For a final 'cut' after stringing up I just bend the string back & forth until it breaks off neat. The remaining stub is much closer to the string wrap stack than I can cut. This gives a very clean final result with little chance of catching on anything or stabbing your finger later."
Attached are a couple of photos illustrating the results obtained both cutting with a tool and the wiggle snap off method. The method works well for all six guitar strings. The resulting stub is captured under the string wrap and it doesn't even snag a polishing cloth. To look at it you may think that the string could come loose but all sizes do hold well. The steps of the stringing technique are:
1. String through hole
2. Bend end 90 degrees
3. Keep bending the string end around the tuner shaft and route it under itself
4. Pull the free end straight up perpendicular to the face of the head
3. Wind to capture the bent up end as winding stack goes down toward head
4. Take hold of the string end and wiggle it about until it breaks off.
Note: Don’t break off any of the strings until you are completely done, tuned up and satisfied with the overall setup. If this method has any downside it’s that you shouldn’t loosen the strings back up other than for normal tuning.
Regards,
Tom
Originally posted by Wittgenstein View PostI used to use a pair of Klein's linesman pliers, but I grew tired of stabbing my fingertips on the little sting that was left. Now I prefer to just wind all the excess wire / string into small loops. I think it looks cleaner / nicer and also prevents finger bruising. I can post a picture when I get home of my guitars.
http://www.flickr.com/photos/43492441@N05/7918292228/
http://www.flickr.com/photos/43492441@N05/7918295278/
Originally posted by Wittgenstein View PostSorry for the bad phone pictures... I plan on buying a camera soon. Here is my acoustic and electric guitar with the strings uncut.
guitar strings | Flickr - Photo Sharing!
guitar | Flickr - Photo Sharing!
[ATTACH=CONFIG]19895[/ATTACH]
I cut mine off close to the tuner shaft and then bend it down. I never ever poke my fingers.
I can get them closer, but there's no need for it.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by David Schwab View PostWhy do you leave all that string on there? Sorry, but that looks ridiculous.
I vaguely remember reading an interview with a bluegrass guy who broke strings at the bridge so often, he figured out a way to "fix" strings in the middle of a tune. He would leave extra string at the peghead like in the pic. When a string broke, he'd pull string from the tuner, tie a knot at the broken end, and wedge the knot into the bridge with a bridge pin. Or something like that.DON'T FEED THE TROLLS!
I like Fender's Safe-T-Post keys or whatever they're called. You cut the string to length before stringing it, but there's no left over end to poke you."In theory, there is no difference between theory and practice. In practice there is."
- Yogi Berra
Originally posted by JoeM View PostI like Fender's Safe-T-Post keys or whatever they're called. You cut the string to length before stringing it, but there's no left over end to poke you.
I always thought that a neat idea.
T"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
Originally posted by big_teee View PostIs that the tuners, you stick the wire in the hole straight down, then turn?
T"In theory, there is no difference between theory and practice. In practice there is."
- Yogi Berra
Originally posted by rjb View PostI find it adds a nice jangle-y effect....
I vaguely remember reading an interview with a bluegrass guy who broke strings at the bridge so often, he figured out a way to "fix" strings in the middle of a tune. He would leave extra string at the peghead like in the pic. When a string broke, he'd pull string from the tuner, tie a knot at the broken end, and wedge the knot into the bridge with a bridge pin. Or something like that.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
