Yes, I forgot to add that. Sorry. I did wire a link between the volume and tone pot.
Pickup wiring problem.. please help!!
Originally posted by LeftySixSoul View PostYes, I forgot to add that. Sorry. I did wire a link between the volume and tone pot."If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
Originally posted by big_teee View PostSounds like your switch is wired wrong, and I still don't see the ground between the Pots.
Here's another diagram to compare to.
STEWMAC.COM : Instructions for CRL 3-way Lever Switch"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
Originally posted by big_teee View PostThey will work either way, You can wire them either way, but flipped is how most lefthand guitars come...
Don't try to understand us, just accept us!
I know- don't try to understand.DON'T FEED THE TROLLS!
Originally posted by rjb View PostDo you have to use antilog vs log pots, or always use linear....
I was waiting on you to think about the audio taper!
I usually use the Audio Pots, and the taper is probably wrong, but don't notice it.
I guess I'm used to it.
Linear would probably be better.
They are both cheap.
I usually run my guitar Vol on 10, or high, so no effect anyway.
I always test Pickups with vol on 10, and control the vol with the amp vol.
That about covers it!
T"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
When you plug in the guitar cord and get the loud buzz, can you turn if down with the volume control? Does the tone control work?
If this is a standard style Tele with a metal control panel, all of the pots are connected via the mounting plate. It really doesn't have to have a ground wire connecting the pot shells.
Originally posted by 52 Bill View PostIf this is a standard style Tele with a metal control panel, all of the pots are connected via the mounting plate. It really doesn't have to have a ground wire connecting the pot shells.
IMO You want the control panel ground, as a bonus Auxiliary ground.
The way I test guitar controls, is with a guitar cord, guitar and DMM.
Set the DMM to a 20k or higher scale.
Plug the cord into the jack, turn the Vol Pot on high, and flip the selector switch to the pickup tested.
Then read across the Cord, you should be able to read the DCR of the Pickup.
turn the vol pot up and down and you will see the resistance change.
Flip to the other pickup, and repeat the process.
Terry
