Pickups that don't respond well to volume knob cleanup...any fixes?
Honestly, this is just futile because as i have said i've tried all the typical things and was looking for something different. It's NOT the pot, the treble bleed value or circuit, it's not about pedals or buffers etc etc etc. It's the pickups. How do i know? Well, besides the fact that there are legions of people with the same issue with these, this is the SECOND guitar i have had with them and the same issue exists no matter what i do. So none of the usual obvious things are going to work. I guess i shouldn't have posted this in the first place because no one is likely to know how to change the pickup itself or a simple inactive tweak in the guitar to change the resonant peak. And no, the pickups are not different than a normal HB in terms of coil size. The coils are the same size as a standard HB. It's the ORIGINAL WRHB from the 70's that had larger coils. And let me clarify what you see as conflicting thoughts that i posted. It DOES change with as little as 8 on the volume as far as TONE goes, but it hardly cleans up gain wise till way down on the volume. I have however found that using less gain at the amp than i want allows them to roll off the drive quicker on the rotation and it then works normally as far as GAIN roll-off, but the tone still gets muddy. But at that point i'm using the amp with less gain than i like. And no, i don't use too much gain for this to work, it's what i have always used with every guitar i owned and none have to be used with less gain to roll it off normally at the guitar.
It comes down to this....the pickup has a resonant peak that just doesn't work well when the volume is lowered. It's likely nothing aside from a rewind will work, so i suppose i'm stuck with them or i can try another pickup like that GFS version, which i probably will. At 10.5k vs 8k for my current ones, and the likelihood the wire is different either in gauge or type means the resonant peak is almost assured to be different. The only thing that will remain the same and could lead to the same issue IF it happens to be the reason for the issue, is the fact the coils are seperated by about 1/8 to 1/4" making for a wider string sensing spread. But then the originals had poles the same distance apart even tho the coils were bigger and they didn't suffer from this issue. Plus with 2 mags per coil that shouldn't matter anyways. And no....bending the G has no weird changes.
The only way you will change things is by experimenting.
You say you know its the pickups?
Then experiment with the pickups.
I know of a bunch of things you could try.
Like I mentioned try another PAF type of pickup temporarily.
See what that sounds like.
If a PAF sounds to your liking?
Then alter the W.R. P/Us to be like a PAF.
Change back to steel poles, and try different bar magnets between them.
I would think A2, A3, A4, A5, would change the sound of things.
If you had the cover off the pickup, you could try some different bobbin winds.
Only experimentation will change it.
Yes, that is time consuming, and takes lots of effort.
GL,
TLast edited by big_teee; 03-06-2016, 07:45 PM."If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
