I have a Strat in right now that has an intrusive hard-edged 50hz buzz. It's fitted with blue (neck), silver (middle) and gold (bridge) Lace Sensors, and a TBX tone control. With any motor running or fluorescent lighting it's really loud - pretty much unusable - especially compared with a Tele or regular Strat. The owner says it used to be fine and just started doing this. The tonality and output levels are good.
Initially I though this was a grounding issue. The guitar has clearly been worked on, as the grounds had previously been lifted from the volume pot and inexpertly re-soldered. I fixed those, plus metered through the grounding and inspected the wiring to make sure everything is OK. It checks out fine and the cavities are factory screened and the pick guard is foil screened on the back.
So as a final test I disconnected each pickup and connected them individually to my bench amp - no guitar wiring connected. They all buzz on their own. At the moment I'm stumped.
Has anyone got any ideas?
