... a higher fundamental harmonic ratio,... [/QUOTE]
It's not clear to me what you are referring to here?
@Chuck
The simplicity of passive pickup and controls does have the fundamental problem, as you alluded to in the first post, of being affected by anything downstream. What I don't like about this is once you've found a guitar, lead, pedals amp combination that works for you it's very hard to change one component without losing the plot, so to speak. For that reason, although anathema to that simplicity, it seems to me that active pups is a better way to go.
If each pup is buffered you potentially gain the ability to control the resonant frequency and level of each pup without affecting any other and it's also unaffected by the load. Downside is a small increase in complexity and a power source. The required buffers can be very simple and only draw a mA of so which gives you something like 500 playing hours from a single battery.
But maybe that takes all the fun out
@Chuck
