Need help figuring out whats wrong
  • #16
    Originally posted by nosaj View Post
    here's a WAG for you.
    Do the guitar have a current working humbucker? If so put the questionable one wired up where the working one is . If the questionable one works just fine then we know you have a wiring/or ground issue.
    Based on the thread the measurement of 6.8k is middle of the road and should be ok. Which is why I suggest trying it in a position that is already working just to make sure is is ok so we can move on.
    nosaj
    wow, am i dumb or are you? Obviously i do not have a working humbucker?
    If i wire my humbucker and it works than it works, no problem, i wouldn't start this topic in the first place. So you are not adressing the problem.
    • #17
      So put the connections for the humbucker where the single coil is. Rhetoric makes people less inclined to help you.
      Good luck
      Nosaj
      Binkie McFartnuggets‏:If we really wanted to know the meaning of life we would have fed Stephen Hawking shrooms a long time ago.
      • #18
        That wasn't very nice. You owe him an apology.
        I think what Jason meant was 'do you have another Humbucker that you could install to test everything'. Check all of your wiring. Test your pickup selector switch as well. Take a reading across where the humbucker is wired to the switch, and where it's grounded to the potentiometer. Test in position 5 so nothing else is in the circuit. The reason it's louder in position 2 is because the middle pickup is working properly while the bridge is not.
        • #19
          Ask for help and then berate someone for trying to help you? WTF? If you don't want advice, just don't ask.
          • #20
            Wow
            "UP here in the Canada we shoot things we don't understand"
            • #21
              Yes, i'm sorry, i got agitated because i want my guitar to work properly sooo bad. Sorry nosaj.
              • #22
                Well lets pickup where you left off. Wire a single coil in the position of the humbucker to test that switch location. Pics might also show if you've got a cold solder joint.
                nosaj
