I have often used a resistor across a pot to change value, but is it possible to change the taper by going from wiper to input lug with a resistor? Heres the problem. I have a P90 LP with 500k pots which i verified are audio taper. But the taper is just too radical. I use overdiven tones all the time and get my cleans by rolling the volume pot down. But It really doesn't clean up much till it's on 2-3. I would like a taper that would get as clean as it is now on 2-3 when on 5. Anyone know if i can solder a resistor across the input lug and wiper to make that happen, and if so what value? I can experiment but i'd like to have an idea of whether it will do what i want and what approximate value to use. Thanks.
volume pot taper tweak?
RG Keen has a good article about this on his GEOFEX.COM web page. Under tech tips: The Secret Life of Pots.
Hopefully I have the link correct here:
http://geofex.com/Article_Folders/po...s/potscret.htmEducation is what you're left with after you have forgotten what you have learned.
Originally posted by daz View PostI have often used a resistor across a pot to change value, but is it possible to change the taper by going from wiper to input lug with a resistor? Heres the problem. I have a P90 LP with 500k pots which i verified are audio taper. But the taper is just too radical. I use overdiven tones all the time and get my cleans by rolling the volume pot down. But It really doesn't clean up much till it's on 2-3. I would like a taper that would get as clean as it is now on 2-3 when on 5. Anyone know if i can solder a resistor across the input lug and wiper to make that happen, and if so what value? I can experiment but i'd like to have an idea of whether it will do what i want and what approximate value to use. Thanks.- Own Opinions Only -
- Likes 1
I got it. I found something in a google search that said to use a value of 20% of the pot value from wiper to ground and that worked perfectly. The keen site....i've seen it but my math skills are comical at best, so looking at those formulas to me is like trying to read a language i never even heard of.
Originally posted by daz View PostI got it. I found something in a google search that said to use a value of 20% of the pot value from wiper to ground and that worked perfectly. .
I think u r right, as the tone on 10 sounds sorta nasally. I'll try wiper to input.
Audio taper pots, at 50% rotation are 10% of the resistance, while Linear is 50% of the total resistance. Allen Bradley Type J pots had a DB taper, which yielded more like 2-3% of total resistance at 50% rotation. Fender makes use of 30% Audio taper pots in their tone control circuits of tube amps. I think some of those controls are 250k. I'd have to look. I looked thru my data sheets of different pot mfgrs, and most of them only offer Linear, Audio (10%) and reverse Audio tapers.
I've attached the data sheet on the Allen Bradley Type J, which on page 3 of 17, it shows all of the pot tapers they offered. You could pencil in the approximation of the 30% Audio taper that Fender has used to get an idea.
Allen Bradley Type J Pots.pdfLogic is an organized way of going wrong with confidence
- Likes 1
Seems the CTS series 450G with A or even C taper should be appropriate: https://www.ctscorp.com/wp-content/uploads/450G.pdf- Own Opinions Only -
The 15% dead zone at the start of CTS audio tapers is somewhat off putting.My band:- http://www.youtube.com/user/RedwingBand
Yes, they are audio and wired correctly. Been modding guitars since the 70s so trust me on that. And the one i checked was about 450k and at 50% rotation the measurements to wiper from the ground and input lugs (after removing all circuitry) is approximately 375k/75.k
I suspect the P90s are the reason i never had this issue b4 because i have always been 99% fender and have only owned 2 P90 guitars. I have used hundreds of pots and never ran into taper like this when using them in fenders.Last edited by daz; 08-29-2020, 12:44 AM.
