leave 8mm of screw protrude?
  • leave 8mm of screw protrude?
    So I got a Suhr Doug Aldrich pickup (53mm / bridge) and it has 8mm of its 3mm screw protruding out the bottom.
    Click image for larger version  Name:	Suhr Aldrich.png Views:	0 Size:	346.3 KB ID:	965455
    so they used a 20mm screw where a 12mm would have been near flush with baseplate. People wonder about trimming these (naturally) but word from Suhr is DO NOT (touch the) trim!! it will change the tone markedly. They recommend drilling 6x holes on the rout bottom to receive the screws on installation.
    Of course I'm thinking maybe I need 40mm screws, and maybe only on some strings, maybe with brass nuts on the guitar back and a full pole through design??
    Opinions? Seriously what would trimming be expected to do?
    Doug Aldrich?
    it will be less metal
      Doug Aldrich?
      touche
        Most guys have screws laying around.
        Change those out and see how they sound with the shorter screws.
        If you don't like the sound of the shorter screws, put the long ones back in.
        T
        Terry
          AFAIK: a slightly lower overall inductance + a wee bit higher Q factor + a tad modified mag field, coupling & balance between coils... as well as altered transients: I think to remember a slower attack but a higher dynamic range with shortened poles in some measurements done here. Very subtle but still noticeable IMHO. YMMV. :-)
