I'd like to hear some opinions on which coil to wind hotter for neck and bridge positions with PAF style buckers. I mostly stick to winding the slug side hotter for both. Its interesting to note that if both coils are wound the same, the slug side will have hotter output because of a shorter, more efficient mangetic circuit than the screw side. You can visibly see this by hooking up an analog meter to ohms and pushing a steel bar down on the slug side then the screw side, the slug side will deflect the needle more, strong output, again because of the shorter magnetic circuit.
Using the Extech meter on a bucker with closely matched coils the slug side will have less midrange and the screw side slightly more. So the slug side wants to be more brighter. To me the more closely matched the two coils are the more sterile sounding the pickup can be, probably because there are more frequencies being cancelled than 60 cycle hum.
I remember reading that Eddie Van Halen talked about the two coils being like a bass and tweeter combination, only now from what I've seen its more like the screw side is the bassier side and the slug side is more treble. I haven't done much testing with having the screw side radically wound hotter than the slug side in neck position and wonder if any of you have messed with this and what conclusions you've arrived at. Humbuckers sure can be very complex the more you try different things with them, I find the Extech very useful here....
