Originally posted by Zhangliqun
View Post
I assume the steel dowels would be to hold the stock and template in place length-wise?
I've got some brad points and some others that look a bit like split points that really cut through steel like butter. But yes, bits sure do like to wander. My drill press is not super high quality and wobbles a bit on its own, but I think a good jig and template should keep it in line.
There is a kind of drill called a pilot-point bit that looks like a spur drill but is intended for metal. The difference is that the central spur isn't sharp, and there are no edge-cutting spurs.
And for split point bits look at picture 7 in Metalworking Basics - Popular Mechanics.
And some general information: Drill bit - Wikipedia, the free encyclopedia.
The split point drills are very good in steel, and one can greatly reduce the wandering by using very short drill bits. These short bits are called "screw machine" drills or lengths, and are roughly one half as long as the "jobbers length" one has in most sets. This matters because flexibility (and thus propensity to wander) varies as the cube of length, so half the length is eight times the stiffness.
As one will be drilling steel with coolant, the black oxide finish is best.
And while High Speed Steel (HSS) alloy is very good, for this kind of repetitious drilling a cobalt alloy bit will work even better. The cobalt HSS alloys are called M42 and the like.
So, we want a cobalt HSS bit with split point and in screw-machine length, with black oxide finish.
The only remaining decision is the angle of the tip, 135 degrees or 118 degrees. Either will work, and one or the other will have less tendency to wander. I would try both and see if it much matters.
Yes, drill bits meeting all these requirements do exist, and are in fact common. MSC's website is down, or I would provide a pointer.
More good points. I've had a few items catch and it isn't pretty.
