so guys is it possible to buy baseplate like this but with 50 mm spacing and only on 1 side holes for screw poles?
paf baseplate with 50 mm spacing
Is .08mm really going to make a difference? That's only .04mm on eeach side.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
That looks like a Stewmac baseplate which I'm fairly certain is 50mm. If it's not a perfect fit, just ream the holes out slightly wider. As Dave says, 0.4mm on each side isn't that much on a baseplate.
It's much more an issue with covers because for aesthetic reasons you can't do any reaming but a slight widening of baseplate holes to accommodate 49.2mm and 50mm parts is no problem.
