Has anyone rigged a tachometer to their winder using a reed switch as a trigger? I assume it could be done. I already use a reed switch for the counter.
Tachometer?
Tachometer?
Tags: None
Originally posted by JGundry View PostHas anyone rigged a tachometer to their winder using a reed switch as a trigger? I assume it could be done. I already use a reed switch for the counter.
If the duty cycle (on/(off+on)) is approximately 50%, many digital voltmeters (DMMs) will measure the speed in rotations per second (frequency in Hertz). Multiply by 60 to get rpm.
I do almost the same thing, measuring the frequency of the change-pulse train from the optical encoder on the bobbin axle. There are 500 change pulses per rotation, so multiply indicated frequency (on the DMM) by 60/500 to yield rpm.
Thanks Joe! I never thought about using a DMM. I will give that a try.
Thanks again Joe. I tried this with my DMM today and it worked like a charm. It confirmed that the method I was using of using to nail down 1200 RPM was working. I have been using strobe effect of the 60hz overhead florescent light by adjusting the winder speed until the bobbins appeared to stand still to get 1200 RPM.
Originally posted by JGundry View PostThanks again Joe. I tried this with my DMM today and it worked like a charm. It confirmed that the method I was using of using to nail down 1200 RPM was working. I have been using strobe effect of the 60hz overhead florescent light by adjusting the winder speed until the bobbins appeared to stand still to get 1200 RPM.
I don't have any pictures but it is really very simple. I'm using a reed switch to trigger a Red Lion Cub 5 (maybe a Cub 4, I always forget, the winder is at my office). The counter is lithium battery powered. All I did to get the RPM was to connect my DMM to a couple of leads I added to where the reed switch goes into the counter. I wanted to pinpoint 1200 RPM so I turned the DMM on and set it to hz/frequency and once it read 20 I knew I was at 1200 RPM since the reed switch is closed only once per revolution. The reed switch is triggered by a small rare earth magnet epoxied into the base plate of my tail stock winder.
