Anybody know a source for 1018 humbucker/P90 poles? And a good source for gold poles in general? The American Music Supply (or whatever the company is called) seems to use an alloy that's even brighter than the nickel poles I have, believe it or not.
1018 steel polepieces
I wonder if the thickness of the nickel plating would have a significant effect on the sound? Is the plating always worn off on the old ones?
Sometime platers will lay down a layer of copper before the final nickel, especially if they are going to plate with a chrome or gold option as well.
I'm willing to bet that the plating changes the sound more than 0.1% of carbon content
Do you mean Guitar Parts USA? Their pole screws are unique, the heads are very shallow, I've seen this on TTops.http://www.SDpickups.com
Stephens Design Pickups
Oh yeah they're 1022, pretty bright stuff. I may be doing another partnered screw pole buy, would need two other guys to go in, probably around $700 each for about 10,000 screws each, a lifetime supply. Gotta do some checking around first. They won't be 1018 though. I'll PM you when and if I think I'm going to do it. I do have alot of 1018 screws from my first buy, might part with some, let me think about it....http://www.SDpickups.com
If you're going to do a group buy on the screws, think of me. I am definitely interested.
Originally posted by Zhangliqun View PostI'd bet against you. I've used 1022 pole shoes and 1018 pole shoes, neither of which were plated with anything, and the sound difference is huge.
Zhangliqun!
Sent you a PM, need to hear back from you....http://www.SDpickups.com
