A look inside a Lane Poor MM5.
  • Originally posted by David King View Post
    David,
    I agree that it makes no difference to you and me but it did make a difference to Lane and I'm sure that's where the confusion comes in where ModulusMK and Henry P are somehow misinterpreting what Lane was saying (which is why I mention it.)
    I hear no audible difference too except excess noise, but in the measurements belwar made there is difference in the peak freq. Without the shielding wire it is higher for about 1.5kHz.
    Henry explained that as balanced (without shielding to ground) and normal signal. In the balanced mode I did get a lot of noise... and I use active electronics w/bypass switch. Where he didn't get noise at all. On the drawing only signal ground is connected to jack, pots's housings also are not grounded and shielding from pickups goes to cavity. Nothing other than this about grounding.
    So there might be something that is missing here (generally speaking).
    • Originally posted by David Schwab View Post
      Basses don't have balanced circuitry. And it's still ground. I also run my shields separate from the coils, but guess what? One end of the coil connects to the shields and ground at the output jack! If it doesn't do so sooner. There is no problem with connecting the grounds and shields together on the back of a pot, since it all goes to the same place, a few inches away.
      Yeah, no difference where shielding connects with ground.
      I'm not sure what Lane thought with this... and how really is.
      However belwar's measurements show the diff.
      • Originally posted by ModulusMK View Post
        If you don't ground a shield, then you are better off not having one in the first place. Shields work because they are grounded. Otherwise they are noise antennas!
        http://coneyislandguitars.com
          Yeah I'm aware of that... maybe it's the thing to have balanced signal up to the jack... but what's the point when it doesn't matter where you connect shield and ground and after that use regular cable. And that are the pots shielded or not. Why is that important to Lane...
          • I think Lane was simply following establish shielding protocol: one path to ground.
            He may also have foreseen the troubles old-school repair folks would have when dealing with a floating ground active buffer system which was where Lane and WAM were headed with the AP 1x1 and the AP 2x1 preamps. He wanted them to get used to the idea that shield was different from PU (-).
              I think he was mixed up about grounds.
              • To change the subject slightly,
                Did you all read those sheets I posted yet?
                "4k turns x 2 precision machine wound match(0.1%) common axis twin coils, hand assembled and shielded to 100% with .001" brass and or copper foil, output cable junction included"
                Well assuming 4k turns is right we should have an easy time determining awg.
                I understand if we still need to talk ad-infinitum about grounds and shields.
                  Well assuming 4k turns is right we should have an easy time determining awg.)
                  Yes! I paid attention on that but was so in this shielding thing I forgot to write about that, haha. You have these scans for a long time?
                  So we have good info from that. DCR is known so we can get the AWG.
                  The coils should be in series, while getting over 6-7K DCR.
                    Looking at the DC resistance vs. turns, I say it's 42 AWG. 40 AWG at that turn count wound would be about 5.5~6K for both coils in series.
                    • Here's something interesting - impedance sweep of a LP M4.0W
                      This is an old pup that I had lying around; never installed.
                      Runs off the WT3 scale
                      check this out:
                      Freq Impedance Phase
                      1.029 8638.192 1.750
                      1.059 8638.192 1.750
                      1.091 8638.192 1.750
                      1.122 8638.192 1.750
                      1.155 8638.192 1.750
                      1.189 8638.192 1.750
                      1.224 8638.192 1.750
                      1.260 8638.192 1.750
                      1.297 8638.192 1.750
                      1.335 8624.951 2.668
                      1.374 8624.951 2.668
                      1.414 8624.951 2.668
                      1.456 8624.951 2.668
                      1.498 8624.951 2.668
                      1.542 8624.951 2.668
                      1.587 8624.951 2.668
                      1.634 8624.951 2.668
                      1.682 8624.951 2.668
                      1.731 8624.951 2.668
                      1.782 8624.951 2.668
                      1.834 8624.951 2.668
                      1.888 8624.951 2.668
                      1.943 8624.951 2.668
                      2.000 8591.016 2.546
                      2.059 8591.016 2.546
                      2.119 8591.016 2.546
                      2.181 8591.016 2.546
                      2.245 8591.016 2.546
                      2.311 8591.016 2.546
                      2.378 8591.016 2.546
                      2.448 8591.016 2.546
                      2.520 8591.016 2.546
                      2.594 8591.016 2.546
                      2.670 8733.073 1.405
                      2.748 8733.073 1.405
                      2.828 8733.073 1.405
                      2.911 8733.073 1.405
                      2.997 8733.073 1.405
                      3.084 8733.073 1.405
                      3.175 8733.073 1.405
                      3.268 8733.073 1.405
                      3.364 8398.033 0.617
                      3.462 8398.033 0.617
                      3.564 8398.033 0.617
                      3.668 8398.033 0.617
                      3.775 8398.033 0.617
                      3.886 8398.033 0.617
                      4.000 8732.399 -0.783
                      4.117 8732.399 -0.783
                      4.238 8732.399 -0.783
                      4.362 8732.399 -0.783
                      4.490 8732.399 -0.783
                      4.621 8732.399 -0.783
                      4.757 8450.194 -1.534
                      4.896 8450.194 -1.534
                      5.040 8450.194 -1.534
                      5.187 8450.194 -1.534
                      5.339 8819.177 -1.289
                      5.496 8819.177 -1.289
                      5.657 8819.177 -1.289
                      5.823 8819.177 -1.289
                      5.993 8381.349 -1.118
                      6.169 8381.349 -1.118
                      6.350 8381.349 -1.118
                      6.536 8381.349 -1.118
                      6.727 8281.629 -0.483
                      6.924 8281.629 -0.483
                      7.127 8281.629 -0.483
                      7.336 7976.455 -0.495
                      7.551 7976.455 -0.495
                      7.772 7976.455 -0.495
                      8.000 7865.689 2.104
                      8.234 7865.689 2.104
                      8.476 7865.689 2.104
                      8.724 7939.407 2.136
                      8.980 7939.407 2.136
                      9.243 7939.407 2.136
                      9.514 8132.559 1.563
                      9.792 8132.559 1.563
                      10.079 8169.897 0.648
                      10.375 8169.897 0.648
                      10.679 8069.310 1.128
                      10.992 8069.310 1.128
                      11.314 7928.609 1.584
                      11.645 7928.609 1.584
                      11.986 8068.424 0.706
                      12.338 8068.424 0.706
                      12.699 8229.327 1.520
                      13.071 8229.327 1.520
                      13.454 8736.955 2.585
                      13.849 8736.955 2.585
                      14.254 8693.210 4.094
                      14.672 8800.440 4.544
                      15.102 8800.440 4.544
                      15.545 8498.132 4.342
                      16.000 8693.845 3.327
                      16.469 8693.845 3.327
                      16.951 8789.472 3.479
                      17.448 8889.821 0.462
                      17.959 8560.518 0.969
                      18.486 8560.518 0.969
                      19.027 8560.083 0.167
                      19.585 8253.033 0.879
                      20.159 8290.305 0.252
                      20.749 8230.995 -0.706
                      21.357 8085.457 -0.846
                      21.983 8010.113 0.466
                      22.627 8024.929 1.400
                      23.290 8257.462 1.732
                      23.973 8342.211 1.675
                      24.675 8351.080 1.579
                      25.398 8406.702 1.106
                      26.143 8565.890 1.632
                      26.909 8372.842 2.685
                      27.697 8393.261 3.661
                      28.509 8271.641 4.296
                      29.344 8326.683 4.476
                      30.204 8394.113 2.495
                      31.089 8308.273 2.275
                      32.000 8508.158 1.747
                      32.938 8335.520 0.902
                      33.903 8308.714 3.167
                      34.896 8322.450 3.458
                      35.919 8243.154 3.571
                      36.971 8390.290 1.672
                      38.055 8466.000 2.030
                      39.170 8399.581 2.392
                      40.317 8421.619 2.871
                      41.499 8251.202 4.168
                      42.715 8256.335 4.673
                      43.967 8469.684 4.425
                      45.255 8539.187 4.551
                      46.581 8455.218 2.989
                      47.946 8317.890 1.355
                      49.351 8300.890 1.291
                      50.797 8318.631 1.211
                      52.285 8317.292 2.250
                      53.817 8165.521 3.008
                      55.394 8067.976 3.956
                      57.018 8031.355 5.616
                      58.688 8108.512 8.253
                      60.408 8189.402 7.890
                      62.178 7985.360 7.394
                      64.000 7994.650 5.304
                      65.875 7870.359 5.116
                      67.806 8201.685 5.506
                      69.792 8469.436 5.304
                      71.838 8459.268 4.270
                      73.943 8462.656 4.108
                      76.109 8539.586 4.727
                      78.339 8594.967 5.504
                      80.635 8549.326 5.587
                      82.998 8489.007 5.144
                      85.430 8527.255 5.040
                      87.933 8448.945 5.527
                      90.510 8252.201 6.444
                      93.162 8331.405 6.162
                      95.892 8603.591 5.188
                      98.701 8574.568 5.538
                      101.594 8333.919 6.429
                      104.571 8118.523 6.741
                      107.635 8299.818 6.478
                      110.789 8652.874 5.587
                      114.035 8978.318 5.210
                      117.377 8878.856 6.170
                      120.816 8864.027 7.181
                      124.356 8790.483 8.099
                      128.000 8782.204 8.424
                      131.751 8374.735 9.053
                      135.611 8115.701 9.399
                      139.585 8299.981 9.414
                      143.675 8506.043 9.494
                      147.885 8635.869 9.152
                      152.219 8749.188 9.152
                      156.679 8768.337 9.904
                      161.270 8520.936 10.592
                      165.995 8381.220 10.351
                      170.860 8492.221 10.758
                      175.866 8764.493 10.734
                      181.019 8838.154 10.809
                      186.324 8888.618 11.653
                      191.783 8804.245 12.274
                      197.403 9090.635 12.233
                      203.187 9251.563 12.346
                      209.141 9446.375 12.805
                      215.269 9423.908 12.488
                      221.577 9247.732 13.378
                      228.070 9264.384 14.652
                      234.753 9365.874 16.112
                      241.632 9327.597 16.122
                      248.712 9123.171 16.447
                      256.000 9016.622 16.574
                      263.501 9118.172 16.929
                      271.223 9363.165 16.712
                      279.170 9490.165 16.597
                      287.350 9534.433 16.095
                      295.770 9280.224 17.657
                      304.437 9132.043 19.077
                      313.358 9318.789 20.138
                      322.540 9459.035 20.552
                      331.991 9587.468 20.837
                      341.719 9565.303 20.941
                      351.732 9812.276 21.928
                      362.039 9813.474 22.137
                      372.647 9721.034 22.731
                      383.567 9671.686 23.377
                      394.806 9809.905 23.877
                      406.375 10039.694 24.030
                      418.282 10319.538 23.740
                      430.539 10146.771 25.593
                      443.155 9975.268 26.686
                      456.140 10101.517 27.068
                      469.506 10512.747 26.972
                      483.264 10652.254 28.367
                      497.424 10708.850 29.303
                      512.000 10714.320 29.511
                      527.003 10725.967 30.157
                      542.445 11110.317 30.420
                      558.340 11302.256 29.898
                      574.701 11345.423 30.086
                      591.541 11206.558 31.164
                      608.874 11288.049 33.483
                      626.715 11605.175 34.440
                      645.080 12018.267 34.252
                      663.982 12220.431 33.849
                      683.438 12594.669 33.707
                      703.464 13462.734 34.487
                      724.077 13903.926 36.045
                      745.294 13961.244 37.828
                      767.133 13747.514 38.070
                      789.612 13694.672 38.098
                      812.749 14016.279 38.209
                      836.565 13701.447 39.035
                      861.078 13759.687 39.749
                      886.309 14489.975 40.792
                      912.280 15084.030 41.516
                      939.012 15453.955 42.006
                      966.527 16156.256 42.938
                      994.849 16681.644 44.077
                      1024.000 17148.356 43.983
                      1054.005 17950.197 44.065
                      1084.890 60690.185 43.246
                      1116.680 81541.189 42.661
                      1149.401 77550.795 43.393
                      1183.081 21163.259 45.200
                      1217.748 20811.301 45.061
                      1253.431 25141.341 43.493
                      1290.159 27150.994 42.564
                      1327.964 27414.175 43.814
                      1366.876 27501.735 42.819
                      1406.929 33646.502 41.039
                      1448.155 42111.609 40.218
                      1490.589 49768.770 40.384
                      1534.266 57206.011 41.528
                      1579.224 68782.265 43.257
                      1625.499 66089.548 42.941
                      1673.129 48260.348 43.144
                      1722.156 58546.132 44.974
                      1772.619 67214.209 42.216
                      1824.561 82000.724 40.382
                      1878.024 232040.638 35.283
                      1933.055 300219.569 32.205
                      1989.697 293982.733 33.415
                      2048.000 944621.923 35.253
                      2108.011 1243157.469 34.117
                      2169.780 1146564.756 30.484
                      2233.360 140684.214 31.006
                      2298.802 316248.352 31.646
                      2366.162 408239.924 31.616
                      2435.496 401678.334 31.575
                      2506.862 294659.605 28.846
                      2580.318 1091007.531 27.825
                      2655.927 1839257.308 27.355
                      2733.752 1800965.935 23.055
                      2813.857 1868277.592 18.665
                      2896.309 1858890.842 18.849
                      2981.178 1324027.100 20.975
                      3068.533 341961.434 20.449
                      3158.448 365311.840 18.903
                      3250.997 441139.236 17.380
                      3346.259 3698577.400 16.042
                      3444.312 5122242.522 14.540
                      3545.238 4826999.836 14.852
                      3649.121 588164.573 16.284
                      3756.049 577575.225 15.299
                      3866.109 315491.684 13.760
                      3979.395 373734.713 11.688
                      4096.000 479853.327 7.590
                      4216.022 908962.257 7.109
                      4339.561 1002606.883 8.526
                      4466.720 791049.395 7.516
                      4597.605 372236.367 8.062
                      4732.325 243939.555 7.640
                      4870.992 274640.255 4.475
                      5013.723 568187.423 2.490
                      5160.637 650008.448 4.270
                      5311.855 541030.366 6.918
                      5467.504 2559842.252 6.654
                      5627.714 3814360.367 3.604
                      5792.619 3743475.991 1.675
                      5962.355 772079.539 1.182
                      6137.066 745153.731 1.695
                      6316.896 282435.458 2.320
                      6501.995 213485.708 5.096
                      6692.518 331389.271 5.711
                      6888.623 1124691.433 5.875
                      7090.476 1155375.291 4.659
                      7298.242 803905.591 3.038
                      7512.097 371045.062 1.712
                      7732.218 408495.100 2.305
                      7958.790 331303.662 2.462
                      8192.000 218000.186 3.262
                      8432.044 230466.482 1.740
                      8679.122 526008.678 1.858
                      8933.439 2927637.490 0.779
                      9195.209 2895953.164 0.192
                      9464.649 1886952.021 -0.556
                      9741.985 725007.915 0.250
                      10027.447 621647.607 0.764
                      10321.273 368036.135 1.877
                      10623.710 358840.553 1.621
                      10935.008 150812.392 2.353
                      11255.428 534761.294 2.924
                      11585.238 773191.759 2.093
                      11924.711 748033.128 -1.868
                      12274.132 196265.732 -1.173
                      12633.791 198421.907 -0.189
                      13003.989 232549.646 0.223
                      13385.035 283614.016 -0.552
                      13777.247 258734.242 -1.042
                      14180.951 143608.805 -1.787
                      14596.485 139693.980 -1.209
                      15024.194 938767.316 -0.656
                      15464.437 1792277.195 0.417
                      15917.579 1771420.419 1.494
                      16384.000 681082.885 1.212
                      16864.088 270993.244 1.141
                      17358.243 399782.360 1.362
                      17866.879 400570.243 1.578
                      18390.418 161557.216 0.632
                      18929.299 138032.934 0.826
                      19483.969 115957.924 -0.129
                      20054.893 116023.345 -0.216
                      20642.546 70678.945 -0.400
                      • Wayne,
                        Thanks,
                        This line: "3444.312[Hz] 5122242.522[Ohms] 14.540[º] " seems significant for having the highest impedance?
                        The plot seems to leave the graph screen just when things were getting interesting..
                        What's the typical phase relationship one sees when doing a sweep of a "typical pickup"?
                        • No clue...
                          Here's some excel charts of this.
                          the phase actually looks fairly coherent, figuring the scope of the issue (lots of f'ing wire on magnet)
                          the thing that gets me is the impedance; my wife said it looks like a mountain range out west... and that's a log scale.
                          I wonder how well any of these measurements are as any indication of how well any pick up loads a preamp input.
                          I saw guys using typical LCR meters... not sure how accurate that'd be. I got the Extech, a BK, and ton of others; they all vary as to accuracy/thing being measured.
                          for instance i get 26nF on the BK and 15nF on the Extech using a 1K freq. measuring the capacitance might be futile using simple LCR meters
                          But the inductance is close on both - around 1.664 H at 1Khz with a Q of ~1.3
                          So go fig...
                          hey dave - check out marketturd when you get a chance.
                          WAM
                          Marketturd Quarterly - rants for Prehensile Chimps
                          Wayne Mitzen - Portfolio
                          • All you guyz need to get one of these imp sweepers.
                            Not bad... I have a VNA for RF stuff; this is pretty cool tho.
                            I talked to the guy that did it for dayton audio, he's the exCarvin dude at Trueaudio ( True Audio: Audio Spectrum Analyzer and Loudspeaker Design Software ). He assured me that it'll measure any passive device within reason.
                            I've tested it on some RC and LC stuff and it works damn good for a $99 USB device.
                            I'd say get yur yerself a cheap ass netbook with one of these and have a blast. And it's great for speaker cabs (what it was designed for).
                            Dayton Audio - WT3 Woofer Tester
                            • A better scaling
                              A better scaling for the vert axis
                              • Wayne,
                                That impedance plot looks more like a harmonic spread with a regular waveform up the decades. Could that be an artifact of something else in the signal chain?
                                I'd have to see some other pickup scans to understand what it could possibly mean.
                                I like your studio shots; Bench vise for MP3 compression. Is that an old panasonic DAT transport?
