Happy NEW YEARS!!!!!!
Wipe them off with a paper towel, put a rubber band around the pickup if it has tape around it. You can use a hair dryer to heat up and melt wax after its dried to soften it up again so you can wipe off stuff you missed. Naptha and a paper towel will also clean off the rest....
Use rubberbands during potting. However, after a few uses, the band becomes stretched and can come unraveled in the wax pot. You gotta check them periodically and if they're too loose, throw them away. If you try to wrap it around the pickup an addtional time to tighten it, it will generally break...sometimes while in the wax pot.
I use paper towels to wipe them off after they cook. After they're done cooling. I use a microfiber cloth to get the wax residue off. I also use a microfiber cloth for final polishing.
I've haven't tried them yet, but I believe Spence uses baby wipes and swears by them as being very effective at removing wax.
I use blue shop towels. They are worth the extra money. Also I don't use rubber bands anymore. They break and splatter wax everywhere. I have found that really rubbing the tape down on the ends keeps it together. If it comes loose or moves I can press it back down and hold it for a few seconds till the wax cools some. I found this to be more effective. Also cloth tape is better for not coming loose if you don't care about vintage correct.
Wrap the taped coils with teflon plumbers tape. That's what I do now, and it works great. I do that before I pot the coils in varnish.
I actually only use a little tape to hold the end down, and for any loose windings. Then I wrap the teflon tape around the coil.
