I may be having a blond momment right now, but I seem to remember someone had a picture of one of Leo Fenders original hand pickup winders. Does anyone have a link to that photo anywhere? I'm just curious and want to see it.
Leo Fenders pickup winder
that's gets me thinkin
Originally posted by belwar View PostThat was my first thought too.. and it looks like a potentiometer sitting behind the counter too..
That motor looks to be something like 1/20th of a horse, probably 1000-1300 rpm
Read Forrest White's book for info on the rubber band....http://www.SDpickups.com
Stephens Design Pickups
The '50 winder isn't all from the 50's the counter is much later. The other winder is Leo Fender's you can see other photos of it on G&L's website gallery. There is a specific reason Leo used rubber bandshttp://www.SDpickups.com
a guess
Originally posted by Possum View PostThere is a specific reason Leo used rubber bands
Built a winder based on that many many moons ago. Out of all my winders is still the easiest and best to use. Simplicity in itself. No traverse, no wire guides just a motor. shaft assy, triac speed adjuster and very accurate mechanical counter. What else is needed. Pic back on the cutting alnico thread page 11.
Originally posted by greenfingers View Post
What is so hilarious about this is that Fender apparently uses this machine for hand winding and uses the modern machines for machine winding. I have seen other video of the Coweco being used for hand winding. The cool sloppy wind that this thing can do is being completely bypassed by using it for hand winding. It never ceases to amaze me that people are of the mind set that machine winding should be or must have been perfect and that if it is not a perfect winding pattern it must have been done by hand.Last edited by JGundry; 01-09-2010, 11:43 PM.
Originally posted by David King View PostWell, from what I've heard the Schatten winder is an unmitigated POS. I doubt it would have outlasted Leo. He probably would have dropped it down an elevator shaft if he could afford one.
Until I get my new winder made I've been powering mine with a variable speed Dewalt hand drill! That works much better.
It's really not much more than an axle with some bearings and a counter. So in that aspect it's not much different than the old Fender winder.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by JGundry View PostHa, hah, hah! That machine is a Coweco automatic coil winder! I already knew the Fender Custom shop had this machine and another like it but had only speculated about when they got it. I had speculated they got it around 1959 as I have the exact same machine and mine is from 1959. But this nails the date of 1956.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
