Originally posted by flyneye
View Post
New CuNiFe Wide Range Humbuckers exist!
Originally posted by Tele-Bob View PostIt's a cool project, that's all.
Yes, it is, but what was the original goal? Using a magnetic material that could be machined more easily than most (for the threads)? Now one could use a steel screw with a neo disk on the bottom.
Another possibility would relate the material's conductivity. Is it different from alnico and steel?
Originally posted by JGundry View PostOrienting of Alnico is done after the magnet is cast. I would think that CuNiFe would also be oriented in the heat treating after the rods are made as well. It should be pretty easy to get a magnet maker to orient the material if you supply them the rods.
See:
http://music-electronics-forum.com/t160/#post1254
Alnico 2/3/4 is not field-cooled; it has two distinct alloy crystals in a non-oriented grain pattern; one alloy is more coercive, the other more magnetic. It can be magnetized in any direction.
Field-cooled Alnico 5(and higher) is mono-crystalline, and the crystals are oriented as you'd expect, and can only be magnetized along the axis of solidification.
Field-cooled Alnico types are better permanent magnets than ones that aren't, so much so that many of you builders partially demagnetize them to get the sound you want.
-drh"Det var helt Texas" is written Nowegian meaning "that's totally Texas." When spoken, it means "that's crazy."
Originally posted by JGundry View PostI would think you could make any of these on a automatic screw machine and have cut threads and then orient them after they are machined. You would avoid any work hardening from have the threads rolled as well. Are you sure the originals had rolled rather than cut threads? I would think that these would be the sort of part that would be cut rather than done with a cold header.
You cannot roll thread or use cutting dies on hardened magnets. They just shatter and alnico is too soft to work before the final heat treating.
Originally posted by Mike Sulzer View PostYes, it is, but what was the original goal? Using a magnetic material that could be machined more easily than most (for the threads)? Now one could use a steel screw with a neo disk on the bottom.
Here's a couple of my scratch built guitars. I built these because I wanted a Ric 360 with an adult size neck and a 25 1/2" scale. Some will say I'm crazy expending such efforts. All I can say is, I love a good project!
These guitars took me about 8 months to complete. I had a Rickenbacker 360 and after a year of owning it, decided it was basically unplayable! So I made some templates and the rest is history. I don't sell any of the guitars I build but the guys at Rickenbacker got real tweeked over this just the same.
Originally posted by Tele-Bob View PostI built these because I wanted a Ric 360 with an adult size neck...
I like the Ric bass necks, but I can't play the guitars at all, and I don't have particularly large hands. Way too narrow. They are almost as bad as Mosrites.
Nice job by the way.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
http://coneyislandguitars.com
Originally posted by Mike Sulzer View PostWhat I am wondering about is why the original pickups used this material.
I find adjustable poles on humbuckers to be useless. They could have just used alnico rods.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by David King View PostNice looking guitars Tele-Bob,
Would CuNiFe have a significantly different inductance effects?
After experimenting with alnico 5 for a few months we were ready to give up on trying to capture the sound of the CuNiFe until we tried cutting the magnets down. That did the trick!
Here's a sound clip of our neck position WRHB mod using alnico 5 magnets. I played the clip straight into a Deluxe Reverb re-issue with no effects but reverb. This went straight into a friends home recorder.
In most people's opinions, this pickup really captures the vibe of a vintage WRHB.
http://home.comcast.net/~nicholas.ca...usic/WRHB7.mp3
The originals WRHB are actually good sounding pickups in the right amp- I think they sound better in something like a fender twin reverb- something that wont get too sloppy in the bass.
I had similar results with al 5 as telenator.
I hope your not making those covers with Fender embossed on them----- YIKES!
Originally posted by jason lollar View PostThe originals WRHB are actually good sounding pickups in the right amp- I think they sound better in something like a fender twin reverb- something that wont get too sloppy in the bass.
This is not a Fender product. The customer supplies their own chrome cover. No way we'd slap Fender covers on there and just sell 'em like that. "YIKES" is right. It makes things a bit inconvenient for those who'd like a real CuNiFe pickup but, it's a different market as well. So far, only two people have complained.
The biggest problem we've found with peoples perception of the original WRHB is that Fender made (as far as we can tell), three different versions, (the black bobbin, enamel wire version sounding the best), and that the magnets on our 6 vintage original pickups were all discharged to about 30% of their potential. This just the nature of CuNiFe.
If any of you have an original WRHB that doesn't sound so great, try charging the magnets and it will wake right up! The only problem is, you need an electric magnet charger to do the job. Passive magnets will not charge the CuNiFe sufficiently.
Anyone with these pickups should probably zap the magnets every 15 to 20 years to keep the sounding great.
Jason, are you having any luck with that FeCrCo? We found that it sounds good in hi-gain applications and oddly enough, in jazz guitars where a tightly focused low end is very desirable. It had very limited appeal for us though in other applications. We're not pursuing it any further.
We have a bunch of FeCrCo2 threaded magnets for sale in small quantities if anyone is interested. #10-24 X .420 long - uncharged.
The major diameter is on the low end of the tolerance for a #10-24 at about .182 diameter. Using a common "A" #10-24 tap works well. It's a tap made to the low end of the tolerance.
Shoot me a line if anyone is interested. I would post this in the "For Sale" section but was unable to.
Originally posted by fieldwrangler View PostDavid -
Really??
Why?
Seth Lover pointed out that he didn't want adjustable poles, or even exposed poles, but it was a marketing point since Fender didn't have adjustable poles.
Most of the pickups I make have blades, and they work just fine. I get a nice string to string balance.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
