Originally posted by Mike Sulzer
View Post
You showed what mattered? You lost me here. Maybe I need to read everything again.
Anyway, my point was, have you wound a humbucker and swapped the A5 for an A2? I told you that I did this, and first it had a big ceramic magnet. The tone changed more than the output. The most dramatic output change was from the ceramic to the A2, but it wasn't huge. But it did take an unpleasant edge off the pickup. I can't find the sound clips for that one.
But here's another real life example. This is a dual rail Strat sized pickup installed in the neck position. This is not as drastic as C8 to A2 however.
This was recorded direct. I use using a clean Twin patch in my Roland VM-3100 digital mixer. I had the levels a little hot.
First you hear it with a C8 magnet. This magnet reads 740G on the North pole.
Ceramic
Next is a small neo which reads over 1500G. At that point my meter goes out of range.
Neo 1
It's a different tonality than the ceramic, with a little more low end.
Next is a much larger neo. I didn't even try reading that directly.
Neo 2
Now that one is a little louder. But not a whole lot.
To try and get a reading on the two neo magnets (until I build the second probe for my meter) I used a 0.08" plastic spacer.
With the spacer I get 645G for the C8, 690G for the small neo and 1450G for the large neo.
Here's the waveforms. You can see the two neo magnets have more output, but what you hear is a lot less drastic.
Ceramic
![](http://www.sgd-lutherie.com/images/ceramic.png)
Neo 1
![](http://www.sgd-lutherie.com/images/neo1.png)
Neo 2
![](http://www.sgd-lutherie.com/images/neo2.png)
